This is what I've planned so far to be my first rack. But please help I barely knowwhat I'm doing.
I'm primarly going for a synth that can alone make vast variety of sounds but I also want to have some fun with generative music. Is this enough for generative? Do I some specific modules?
I'm already thinking of switching the MATHS for Behringer 140 because of my budjet, so over 1000€ probably would be too much.
Also is the case too small? Should I get a bigger case or choose more compact modules?
(I'm also thinking of building on cre8audio NiftyCase so theres some of the utility of you wondering)
As NoSky already mentioned, if you're on strict budget then I'd swap Maths for Abacus which is significantly cheaper.
I'd also swap Koma VCA for Behringer Four Play (clone of Intellijel Quad VCA) and add some LFOs to provide modulation, attenuverter and some multiutility module with mixer and mult.
Behringer has Four LFO (clone of Xaoc Batumi) and Steps (clone of Mutable Instruments Stages). You can also load Qiemem's custom firmware to it which will allow you to control LFO polarity and frequency range though I don't recommend it if you're complete beginner. https://github.com/qiemem/eurorack/tree/v1.0.0/stages
There are clones of Mutable Instruments Links and Kinks which are great multi-utility modules. If you're in UK BeepBoopElectronics has lot of various utility modules. https://beepboopelectronics.co.uk/
I'm also not sure if you have some kind of mixer or audio interface but if not you'll need some output module to plug your headphones in. BeepBoopElectronics also has simple 2hp headphone output module.
1) Yes, the case it too small.
2) Things you're missing that can be key components to a well rounded modular setup: Clocking with mult/div, utilities to control signal strength and polairty, a proper mixer with aux send/return for your effects (and thereby a proper output module, whether it be the audio mixer itself as here, or a separate module), good robust effects (a multi-FX 3HP spin chip module isn't going to get you super exciting results effects-wise) -- the effects here can be nabbed on the secondhand market for below average prices currently (mostly). A Versio is a bit pricier but it allows you access to all the 7+ firmwares in the line, giving you an effects powerhouse, so long as you have a PC and a micro USB cable to change them out when you wish. The change out process is very easy.
My advice: Double the size of your case, get a proper mixer like a D.O. Mixx by Blood Cells Audio or at least a Cosmix by Cosmotronoic, get a couple decent effects, get a Pam's NewWorkout or some base control for BPM and clock divisions/multiplications, get a proper audio VCA like a Tallin. Also, ditch all the Behringer crap bc it's a garbage company and you'll be stuck with their worthless toys with no resale potential. Here's what I'd probably try to put together in your shoes, with a mind to keep the cost somewhat under control.
