Hi all! Sorry if this is a newbie question but this is an area of expertise that I lack knowledge in. I just got a Motu M4 audio interface (dc coupled) with the intention of using the Pam Sync plugin to send clock and run signals to my Pamela's Pro Workout. I'm just not sure which cables I should get. I have been trying to find this information online and have not been able to find it. Should I be using a 1/4” TRS to 3.5mm TS cable, a 1/4" TS to 3.5mm TS cable, or does it even matter?. ALM sells both on their website but does not mention which one I should use. Expert Sleepers sells a 1/4” TRS to 3.5mm TS cable that is used for interfacing with the silent way plugin so I'm guessing I should use the same? The store I get my gear from is a 12 hour drive away so it's not a quick run to the store to return some cables if I get the wrong ones. I even called them and they didn't seem sure which one I should use either. If anyone could give me some advice on this it would be greatly appreciated. Thanks
geusensdriesmusic
PPW has dedicated 3.5mm TS inputs. Your Motu has 1/4" outputs. You'll need two of those outs to send both clock and run gate.
I"d recommend getting two 1/4" to 3.5mm TS adapter cables. Don't use adapter plugs because sooner or later they'll fail.
-- x-minus-one
ambient • electronica • microtonality
diy eurorack & pedal builder • bassist
My music on Bandcamp: https://driesgeusens.bandcamp.com/
So TS to TS. Got it. Thanks for the advice!
