Hey everyone,
Today I tested out this little live set — a mix of underground techno and drone at 165 BPM.
I made a small patch using the StolperBeat and the Voltage Block as sequencers to create pattern transitions. The Rample handles my drums and the Bohm my kick, both running through the 1010music FXBOX at the end of the chain. I use the Z8000 on the Rample to play the layers.
My mixer is the D.O.MIXX, and the drum compressor is the MESSOR.
For the drones:
The Polimaths generates LFO-like movements, which vary because the Spread parameter is modulated by another LFO, the Contour 1.
I use a Mysterion and two MMGs to create shifting rhythmic textures that I modulate with the StolperBeat.
The Plaits plays vocal-style voices that are amplified with Warps, and modulated by the Polimaths.
The Vhikk X creates drones also modulated by the Polimaths.
I mix all the drone layers with a Vortices.
Thanks for listening — see you soon! ;)
