Hello fellow Eurorackers,
I have been building my own racks since I first fell in love with modular many years ago. During this time I experimented with different materials, electronics as well as with my own "hacks" for cable management.
This is my first case that is ready to be sold that contains all the lessons learned. Every screw, component and material have been carefully chosen to be of highest quality and if you hate cable spaghetti you will love the special features.
I hope it will bring you as much joy as it does to me.
  • 3 x 126 hp with threaded inserts
  • Integrated power supply & bus boards (Konstant Lab):
    • HAMMR 100 Power Supply Unit
    • 3x Bus Boards (16 connectors each)
    • Power Brick (Meanwell 120W) with Power Cable
  • Special features
    • Dust-proof Air Filters
    • Channels and Wormholes for Cable Management
    • Cable Connection Cogs
    • Shelf for Powerbrick and Patch Cables
  • Dimensions
    • Width: 700 mm
    • Height: 350 mm
    • Depth: 350 mm
    • Weight: 13 kg
All components are produced in EU. Each box is assembled by my hands :)
Professional Electronics
I want only the best for your modules. That is why I partenred with Konstant lab, the market leader in eurorack electronics. DRONEBox has a built-in HammerPWR, a whopping 100W power supply, which is plenty for even the most hungry modules. It comes with a 120W power brick (Meanwell GST120A-P1M) as well as three pocket bus boards for each row, so all you have to do is plug in your favourite modules.
Outputs: +12V / 5A (splited to two branches 2.5A + 2.5A), -12V / 2.5A, +5V / 2A
Input: 20V DC
Protections: Input filter, Input overvoltage. Input reverse polarity voltage protection. Output overvoltage. Output short circuit – automatic recovery. Output over current – automatic recovery. All output protections are independent for each rail.
Efficiency: 90%
Additional: Dual input common mode LC filter with high efficiency of canceling noise and interference from input connector. Additional input filter for each converter for minimal output noise and interferences. LEDs indicate present and drop of output voltage. +12V output is splited to two branches for modules separation and minimalize of voltage dropout.
For all other features (which there are many), visit my website drone-audio.com
And since Black is the color of DRONE AUDIO, there is a one-time limited offer for Black Friday!
