Looking for advice on my first rack. I put a lot of thought into it but I'm still very confused until I get hands on with this stuff, so I am seeking advice/opinions.
So far I own Maths, Monsoon and Beehive. I will be sequencing externally and can get drums externally but I did add the Expert Sleepers to the build for drums in a pinch and also the many other things it can do. I'll probably be using my polyend tracker for drums and sequencing via midivolts 4 channel cv/gate and clock output. I also have a few other things I could use if needed but I love my tracker and would be the preferred device.
My end goal is to have something to make spacey ambient stuff, and sounds and melodies I can sample for hiphop and electronic music production.
I have a B2600 I will be using with the rack for a while as I build up my collection.
I am getting my amp and mixer next. What modules should I be looking to get afterwards?
I would like to expand to a 6u build at some point.
noodle_hut
Maths sure takes up a lot of room.
Monsoon + Disting might be a challenge to control using what's there.
When I've run them in serial, the details turned mushy and high end gets lost,
but I like that dual filter. It works well as a mixer with three inputs on each filter,
so maybe those three will be interesting together.
The usual next step, the boring things; active mults, attenuator/offsets, CV mixers,
maybe a quantizer if you're doing note-ey stuff.
That set should be fun.
