hello. as the title says new to tbis i have the maths and plaits and make noise easel already
1. will a 4 ms 48x pod have enough juice if i add a flying bus. i think based off of these numbers it will but i would love to be sure
2. are there redundant or un needed modules here i do mostly experimental, ambient, drone, noise and variations inbetween
thank you for any thoughts on this
Jukeshoe
As someone with experience with ms pods, I'd highly suggest starting with a larger case that offers room to grow. Tip Top Mantis cases (with which I also have experience) provide the best bang for your buck, as well as lots of room to grow.
― Friedrich Nietzsche
thank you , i wasnt aware of that brand case perhaps for the more distant future. for now tryiny to stay in this pod for a while
You should be fine as far as power.
Looks like everything there could contribute to fun patches.
I like those tiny builds. I call them spirit radios.
thats a great name for them, thanks for the power info, and that what i have will play nicely together. much appriciated. i was thinking about replacing the ochd expander with a junction from acid rain, for more overall unification. would this be a good move?
Just try it if you can.
As much as I think a build is just right, it always gets changed,
and I don't think I've ever done the same setup twice.
Eurorack resists being static by design. I guess that's its charm.
That elusive perfect box.
