Hi all, just wanted to share my latest creation, which used some eurorack modules ^_^
Soft Techno Lullaby by megoth
It started with a combo of the Turing Machine and its extension, Volts, leading into the Penrose Quantizer, and finally into one of the main oscillators in the Solar 42f. After playing around a bit, I found a sequence that became the foundation of the song.
Adding to this was a generative patch using the Oxi One, which I played on the Oxi Coral. Both of these patches were mixed with Clouds to add some granular details.
After figuring out the melodic base, I added some beats using Ultra-Kick and Collide 4 mainly, but with some percussion elements from Rample and hihats from Hats808 and Mutant Hihats.
These elements created a melodic groove which I then layered with some software synths in Ableton Live, using Serum 2 and Decent Sampler to add some longer sounds that tie it all together.
Hope you enjoy it ^_^
Volnay
Nice track! What did you use to sequence the drums?
Thank you ^_^
I'm mainly using Oxi One as main sequencer for the drums, but I also use Steppy as sequencer for hihats (I have Mutant Hihats and Hats808). I could run everything through Oxi One, but I like "outsourcing" hihats to Steppy.
This is the current state of the drum machine that I'm developing. As it stands, I usually don't need Steppy, but I plan to add more drum sounds in the future, at which point it's good to have "freed" the handling of four gate signals away from the main sequencer.
