I need a set of switches so cc out from the polyend can control the following things
1) select bus transmitter so it can have 1-16 presets from push3
2) switching 4gate/4cvoct (8) inputs to 8 assigned outputs buffered. this can reallocate voices and the switching would be changing a preset of the 8in/8out switch to all variations of which voice is played by the mutant brain from push3's 4 tracks
3) another level of buffered switch to redirect 8 to this OR/AND that (so either, or BOTH) of 16 outputs. 8 would go to the 2nd set of 4 voices, and 16 (when on those presets) would go to BOTH sets of 4 voices and essentially stack them in the mixer. of course buffered so the same notes are playing.
4) CC out from polyend to individually change the presets of 8 voices... so 8 outputs... plan for one cv input dedicated for each digital osc to just change preseet. that way with 8 knobs on the push3, I can scroll through the appropriate sound. another session I may make other sounds and save more presets on each voice. maybe there's a way to give them all the same presets or something...
5) cc or cv out... to switch octaves. 8 outs.
6) already there's too many outs so we need to chain the polyends. get 32 cc outs.
7) GOAL: sit on couch with push3 and compose using the eurorack and synths, not touching the synths, Another session, touch the synths, make new presets. also goal is to almost never repatch the system after initial patch is setup.
8) Need colored velcro straps to indicate permanent patches... should help me not unpatch a complex routing.
9) many things will be not permanent patch. they will be up for playtime and would essentially tap into the chain of voices somehow... I might need to develop an alternate setting to route the bloom v2 or whatever into the switch system. or route the mutant brain, or route the bmk2's. but what if I wnat mutant into bmk2 or the bloom v2 into bmk2... there's gotta be a way to switch that around after bufferd multing... seems easy. that's what we need to develop next.
