Just finished my 6 NLC FM-OP's, so here's my first patch using all 6 voices.
Four FM-OP's are routed through the Natural Gates, the remaining two are patched straight into Beads.
Enjoy!
Enjoy!
ambient • electronica • microtonality
diy eurorack & pedal builder • bassist
My music on Bandcamp: https://driesgeusens.bandcamp.com/
You really went all in on the NLC didn't ya! ;-)
Kinda, yeah. Lots of DIY in there, which I think is excellent.
-- wishbonebrewery
I'm only capable of thru-hole DIY builds so unless, like with Sloths, I got someone to build me something most of the NLC stuff is off-limits to me.
Allow me to disagree. If you're able to build thru-hole, you'd be able to succesfully build SMD. You just need a different set of tools, namely a very thin soldering iron - I prefer a needle - thin wire, some flux and a magnifying glass to get you started. I've used a hot air station solely for soldering QFN packages, but anything down to 0604 size is perfectly doable by hand.
If you have a Turing Machine, grab a Pulses expander kit: ideal to start building SMD! There's many others available which aren't hard at all (NLC, Beers to name a few).
-- wishbonebrewery
I completely agree with your dissagree, with the right tools i probably could do it.
In reality, I've enough things to think about without learning a new skill set just at the moment haha
