Hi
What do u guys think for my Updated first Rack
Ive added the Behringers due to the cost but will swap them out if i find out that Eurorack is for me
What would u guys change if it was your Rack
Thanks
Hi
Thanks
Hi, it seems functional enough, but I don't see much in the way of "modular synthesis" for lack of a better word.
You have 4-6 channels of samples, a complete drum voice and two complete synth voices.
What's drawing you to Eurorack, or what do you expect to get out of this rack that you couldn't get out of a Digitakt plus an analogue monosynth for a third of the price (not counting the Oxi) or even a Polyend Play for half that.
Thanks for the Reply
Ive all ready got all the Digitakt Rytm Digitone Octatrack plus synths etc but I just want to try something different be more hands on but eurorack is completely new to me so i guess im buying things blind
I want to try and build a Melodic Techno rack
Any advice help would be great
Thanks
-- teataine
Agreed with teataine, you have a fine synth here, but are missing out on two of the things that make modular synths so special - the ability to modulate parameters and the ability to create different signal paths on the same synth. I tend to think of my rack as a palette from which I build a new instrument each time I construct a patch. So, instead of getting modules that copy and paste what a monosynth or sequencer can do, think about things like modulators (e.g., lfos, random voltages, etc.), vcas, and utilities, and think about modules that allow for a lot of patching opprotunities. Feel free to check out my older comments, I've written a lot about utilities and planning a rack. I initially came here for advice myself with a rack plan that in retrospect would never have worked and would have left me dissatisfied with the hobby. Instead I restrained my buying to utilities and essentials until I had a solid foundation and understanding if what I was aiming for, only then branching into effects or drums or even oscillstors. Take some time to familiarize yourself with the above module types first, watch a ton of videos, and read manuals before buying. Hope that helps!
Here's an practical idea, building on what teatine and HGsynth said.
Rather than getting the Erica Synths Bass Drum or Bassline, you can get any 'normal' VCO by Erica Synths, combine it with a envelope generator / modulator (NANO ARC, Make Noise Maths, others), an acid filter and a VCA to get the same result, but in this case you can also wire everything differently and get things you didn't think of when you were shopping for a bass drum. That's the area that Eurorack shines in, and it's difficult to do this with regular synths.
