Hello,
I was planning to get the Doepfer A188-2 because it has several simultaneous outputs with different delays available simultaneoulsy. However it is discontinued.
Is there any alternative? Or should I rather buy several simple (single-output) modules?
Thank you for your suggestions.
Jukeshoe
I've got the 188-2, and it's a very deep module, physically. So if you find one and decide to go this way, make certain it fits your case. You'll also need a filter to remove clock noise. I use the A-108.
Check out the A-188-1A, - 1B, -1C, -1D, -1X, and/or -1Y to see how they've split the larger tapped bbd into several smaller units with specific stage ranges.
I'm sure other BBD's exist from other companies, but that's probably a good place to start.
Best of luck!
― Friedrich Nietzsche
