AcdNrg
Maybe I don´t know the right keyboard shortcut or setting, but there is an issue with pasting modules in larger racks: The pasting target is always the first available matching space.
While this is not a problem with small racks, it becomes really annoying when having, say, 12 rows: You need to manually pull down the module across multiple pages and the autoscroll helps a bit, but is a little wonky in its behaviour. All ok for a module or two, but it gets annoying really quickly.
Here is how this could work:
a) add an icon to the mouseover right below the > buttons that pulls the number of rows of this rack and let´s you select a target row (similar to the swap rows behaviour in edit/swap rows, just "insert in row x" as a dropdown selection.
or
b) set a rack wide parameter (in edit mode) that determines the row that things get pasted to instead of "lowest row number"
or
c) in rack edit mode add a radio button that says "Reverse Paste", ie pasting to "highest row number instead of lowest".
a) would be nicest, as determined, adding a notification if there is no space in that row. comfort feature: grey out rows that don´t have enough space for the module in the clipboard. c) could be a lot easier, as it just reverses the existing paste algorithm, but it keeps the issue alive, just for the middle rows. Still a great improvement.
One more option: selecting multiple modules (CTRL = selecting by clicking, SHIFT = from ... to..). But that would change the clipboard content and I assume then mess with a few other functionalities.
Comments please :) ?
I had already proposed a possible solution for this annoying problem three years ago:
https://modulargrid.net/e/forum/posts/view/35172
