tripfacesmiledotcom
Anyone else experiencing weird power issues with the Audio Gear Obsession DYNAMICENGINE compressor limiter?
I've already contacted the manufacturer shortly after purchasing this module, and sent it to them for inspection. Unfortunately, they couldn't reproduce the problem and suggested keeping the module in its own case, which seems impractical and defeats the purpose of Eurorack.
Original Issue:
Mounted in my Doepfer Monster case.
Nothing plugged into the I/O.
Attack set to fastest (see image1 - Full module setup).
When powered up, the compressor appears fully engaged, with the blue LEDs lit from top to bottom (see image2 - LEDs fully lit). To resolve this, I turn the attack knob to slower, and the LEDs fade back to unlit.
I have already tried putting this in my other cases, including: doepfer monster 6u base, monster 9u case, monster 12u case, MDLR 14u case, and IntelliJel palette cases.
I have also tried numerous different power cables with module.
None of these fix this problem.
TripFaceSmile.com
I don't have any exprience with this module, but unless all your racks are running close to their power limit it really sound like something is wrong with the module.
I'd recommend to do current measurements to see if it exceeds the rated 160mA on any of the rails.
