Hello,
I have issues I am trying to find a format converter that takes modular 1/8 to 1/4. I need 16 channels to my mixer. So something that has 8 channels would be nice. So people that are using out board mixers in their setup how are you connecting this up?
Jason
So, after looking at around 2,000 modules I found this brand Mazzatron. So, 8 hp with 8 jacks of 1/8 to 1/4.
Having 16 guitar cables snaked out of a rack seems problematic.
That's a lot of weight pulling on a module or two and probably why you havn't found one yet.
The Mazzatron module pushes the 1/4s out the back or the module.
I don't know how that could work very well.
I know you've got a plan, but you might be forced into having submixes.
im thinking about the same. maybe check out erica synths link. that could work. also doepfer has one but one with 2 outs that would ge a little expensive and would take a lot of rack space too.
Hello,
Jason
These are valid concerns. Maybe I can find one of the nw2s modules. These are on DB25 snakes. The company seems out of bussiness but I am sure some will pop up on reverb.
That Mazzatron module doesn't need any power and you won't need to play around with it much when it is set up. I can't help but think your best bet is to not rack it, but just kinda have it out on its own so it doesn't get pulled on due to being in a fixed position. You can always cover the sides with something if you're worried about that.
It also would be possible to use only cables without any additional module.
https://schneidersladen.de/de/cordial-cpi-3-pz
Icant recommend the cordial ones. I trusted them before i bought the expensive modular cables from them. They are the worst of all i can tell and the cables you posted got the same jackes. Just my experience.
I have the hosa version of those cables. My mixer is on DB25 connectors, so I just have patchbay in an 19 equiment rack on the of side my desk. That is what I doing now. I just wanted to clean up all the patch cable and run everything to a central location.
