Loersatz
Hi to all :)
Not sure this is the right place but...
I am using an Octatrack Mk2 (referred to as OT) as a mixer/remixer for my modular. It sums 2 mono signals from a Ladik A-541 - https://modulargrid.net/e/ladik-a-541 (usually 1 channel for kick and the other for bass) and a stereo signal from the Make Noise XOH - https://modulargrid.net/e/make-noise-xoh.
I am using the filter distortion in the OT on kicks and generally to beef up the sound coming from my modular.
What Eurorack module could do the same type of "filter distortion" or any type of distortion to get to the same result?
Any idea?
I am also using the filter distortion from the OT on the Master track in the OT to beef up the mix... OT is then going into a FMR RNC and finally an Analog Heat Mk2. For info :)
Current rack: ModularGrid Rack
"I've seen things you people wouldn't believe... Attack ships on fire off the shoulder of Orion. I watched C-Beams glitter in the dark near the Tannhäuser Gates.
All those moments will be lost in time, like tears in rain. Time to die..." R. Hauer
