phinland
Video:
Manual: https://docs.google.com/document/d/1KIR9YYltkQTQa3_RPCA2l4PnV_vMzlKGQDvNpvCzeqA
Notification List: https://forms.gle/7WyFvb4PR82zyixM7
Strange-R introduces a totally new way to do sequencing: Melodic Contour Sequencing. It’s extremely powerful at generating recursive melodies, loops and randomness, making generative melodies that sound like human melodies, or live-varying external sequences sent to its input, but never losing sight of your direct realtime performative control.
The majority of its melodic power comes from just two controls…
ρ (Rho = Correlation = Melodic Direction)
∆ (Delta = Deviation = Melodic Jumpiness)
These two simple intuitive controls both originate the melodic material, and then also determine how it is manipulated by 3 independent ‘phrase loopers’ to walk or jump the loop up and down. All this is combined in a unique internal 'micro-patch' with the quantizer (able to do automatic Modal Interchange and Circle of Fifths modulation), two chaotic LFOs, two flavours of noise (analogue and PRNG with sample rate and bit depth control) full CV control over every function, as well as the input which permits live re-composition and variation of anything you send it.
The result is a generative powerhouse and mother-of-all-random source utilities.
* Custom SI Random Walk
* Music theory aware quantizer (automatic Modal Interchange, Circle of 5ths, root note set)
* 3 independent loopers able to hold over 4000 events
* Built in probabilistic TrEG envelopes
* 2 Chaotic LFOs
* External CV Input for live manipulation of an external sequence
* External Clock Input for eternal sync with no lower bpm limit
* Clocks into audio to use as VCO (tri/saw inc.VCO sync!)
* All functions CV controlable
* Non-sprung joystick control with direct JS XY output +/-8v
* CV folder/wrapper
* Quantizer can be used as live input keyboard with chiptune pseudopolyphony
* Full memory recall into 7 scenes
* Special input/output calibration mode
* Firmware updatable via micro SD Card
Stochastic Instruments Ltd.
Rethink Random//Perform Process//Create Chaos
Save the World Entire: Vegan
End the holocaust. Change our world with science.
noodle_hut
Pretty cool Phin. Didn't see that coming.
Another module..
I guess I have to get it, probably the larger one.
Another module...
The SIG is in most everything I do, it's wonderful.
Another module....
Wow. Just wow. That looks like FUN!
The SIG+ is a recent addition to my rack and I've been loving it. Playing the SIG+ feels like having a conversation with my synth, and I'm still only part of the way through figuring out everything it can do.
If you don't mind the question, I'm curious if you envision the Strange-R as a compliment to the SIG? I'd love to hear how you envision the two modules working together, if at all.
Thanks!
