A small all-in-one synth from C.H.A.I.R., distributed by Befaco.
Straightforward build, but there are many tight solder points. Marketed as a beginner kit, but I would recommend you do something easier first and do this as 3-4th kit once you have your solder skills increased.
Sounds fine, good external modification inputs. Would be great for a small rack, get many things in one unit, vco, loo, filter.
Build
CHAIR
Thanks for the review! Just saw this now. Maybe you have noticed we have published some modification suggestions for the use of Ilse in an Eurorack context.
https://discourse.chair.audio/t/ilse-build-instructions-for-revision-4/151
You're welcome, it's a fine unit! I'll take a look at the mods!
--ck
