Keychain Holder, a keychain designed for synthesizer enthusiasts, inspired by Vaemiās oscillator OSI-OP design. The Keychain Holder works with an adapter. It has a fitting at the top that allows it to be hung on the wall. The design includes lights. While the Vaemi logo in the center stays lit continuously, the Vaemi text above the jack inputs lights up one by one as you plug in the jacks. The product comes with 5 jack keychains. You can attach these jacks to the keys you use daily, and when you arrive home or at your workplace, you can hang your keys on this holder. The knob helps you adjust the overall brightness of the lights. Additionally, there is an On/Off switch.
Keychain Holder Features:
-Operates with Adapter: The Keychain Holder is ready for use by receiving power through an adapter.
-Wall-Mountable Design: It can be easily mounted on the wall thanks to the fitting at the top.
-Lighted Design: The Vaemi logo in the center stays continuously lit, while the Vaemi text above the jack inputs lights up one by one as you plug in the jacks.
-Adjustable Light Level: You can easily adjust the overall brightness of the lights with the knob.
-On/Off Switch: The product includes an On/Off switch.
Package Contents:
-1 Keychain Holder
-5 Jack Keychains
-Adapter not included
With a 12-volt adapter, it draws around 20mA of current. It operates comfortably with 12-20V, 100mA adapters.
Operating Voltage Range: 12-20V
Power Consumption: 0.24W
Dimensions: 150mm (length) x 75mm (width) x 58mm (height)
It is not a musical instrument. It is a gift item.
https://en.vaemi.net/product-page/keychain-holder-diy-or-assembled
https://reverb.com/item/84260130
https://www.etsy.com/listing/1780922689
