Hi all, I need some help please.
I want to sequence my BIA by feeding it sets of upto 8 preset cv's per trigger.
So basically set one would create a kick, set two a snare set 3 hats etc etc.
So I then need to be able to choose which preset cv's are output
on the beats of the bar. EG step 1 = Kick preset cv's, step 2 Hat cv's, step 3 Hat cv's, step 4 snare cv's.
So what I think I need is a sequencer that has eight lanes and is CV addressable. But I could be wrong.
I have tried finding such a module with no luck.
Any advice would be great as I'm still fairly new to all this.
Traffic from Jasmine & Olive Trees does up to 3.
I think it's sort of what you're looking for
Thanks for the suggestion.
That is exactly what I'm talking about but with more than three channels.
Equinseuorcha
checkout out the "voltage block" CV sequencer module, could be a good solution.
if you’re into the idea of a stand alone sequencer this wizard made this whole track with only 1 BIA and the Oxi One sequencer:
VONDENFUNKEN
There are many approaches depending on the modules you have.
I do it with traffic from olive tress at the moment.
(Traffic, let you defince cv states, so you can get 3 sounds like a kick, a snare and a hat, to be triggered seperately out of the BIA.)
Back in the days, I used Mimetic Digitalis with Lapsus Os. It gives in sum 8 outputs. (4 sequences, each 2 times)
Voltage block will work well.
You can do it very well with Pamelas Pro Workout. (8 outs)
With cross channel logic, you get amazing results
Greetings
Chris
I have Pam's Pro Workout but I couldn't work out how to do what I'm suggesting with it.
The Oxi One sequencer is amazing and would totally do it but its way out the budget.
Malekko Voltage Block looks like it will do the job exactly.
Great suggestion !
Thanks all.
VONDENFUNKEN
As you own Pams already, I think its worth to try it with Pams.
I had great results with it.
Dont overlook its great powers.
You can do it all with it.
different trippy clock divisions and patterns work well on the BIA inputs.
Try to play with Phase, With and Level on Pams with different settings each on the channels, if needed with a additional attenuverter, polarizer.
like set the Phase 25 % off on (attack of the BIA) for noise/hats
looped random on (algorithms of BIA)
a different looped random on (octaves of BIA)
on fold
on harmonics
and so on....
When you find something that works, you can save the settings of the channels as presets and recall them later, to play the same patterns, when you need it.
(may combine it with euclidean patterns)
Also the turing maschine functionality is very useful.
A big thing are the logic functions.
You can set different operations to Mix Channels, like combine channel 1 and 2 and get the Min, Max and so on
I enjoy it very much to do that stuff.
Greetings
Chris
RE the Pams suggestion..
All cool ideas. I have played about with quite a few of them already.
What I meant was, I can't work out how to achieve my specific idea with Pams.
I thought you where suggesting it could be done.
