Vaemi
XFMR Euro DI : Audio Demo : Vaemi (Eurorack)
As VAEMI, we designed the Euro DI in the Eurorack module format, which can be used for all digital or analog equipment, synthesizers, and drum machines ranging from line level devices to high voltage synthesizer levels. In this way, you can input the unbalanced sound signals of your equipment into your microphone preamp with a balanced XLR connector.
Key features include:
  • Balanced XLR Output
  • Neutrik XLR connectors
  • Enables the transmission of audio signals over long distances
  • Clean and transparent sound
  • 0 degree phase shift
  • Accurate isolation from electrical noise in the audio signal
  • -12dB Pad switch
  • 180 degree phase switch
  • GND Lift switch
To watch the full video:
