I know it's wide in modules,setup etc ....while talking about a modular system.
I just would like to know if some people here could consider my system as a system with ''load'' of modulation modules.
Thanks
Not a bad start but I recommend a larger case and more utilities and maybe some effects?
Thanks
Yes modulation is way more important than too many voice oscillator modules. If you want to keep the smaller case, consider smaller sized hp modules that perform these modular tasks like 0chd from Divkid that is way smaller than Rampage and still gives you tons of modulation. Also consider getting a quad VCA module and attenuator. A filter would be great add on as well.
-- benscott
I have an empty rackbrute 3U 88hp.
-- benscott
Many thanks, your answer helps a lot .
halbroome
That Hysteria module is a lot of fun (and modulates, as well!).
-- halbroome
A VCO can be a modulator ?
Thanks
yes... almost anything "can" be a modulation source...
usually it helps if your modulation source is slower than what you are modulating...
all signals in modular are just electricity varying in frequency, amplitude band shape... so to a large extent anything can be anything...
the only real caveats are that for a signal to be audible it needs to be both fast enough (>20Hz ish) and slow enough (
the only real caveats are that for a signal to be audible it needs to be both fast enough (>20Hz ish) and slow enough ( < 20KHz ish) and that it's not a great idea to send DC signals (slow unipolar signals) to speakers - as this can damage them...
and try not to be so loud that you damage your hearing!
