Hi everyone,
super beginner question - my very first step is that i want to mount Moog Mavis on my new eurorack mount
this is my rack mount product plus power unit, the tip top
https://www.thomann.de/gb/tiptop_audio_happy_ending_kit_black_eu.htm
Anyway.... i see that the power in point for rack mount on the Mavis is male with 10 pins in two rows five pins,
While the scarf cable on the tip top power supply is male with 16 pins in two rows of 8
I presume I need an adapter type short section of cable with the diffent types of female rows each end?
or are there other factors that make this more complex?
Also, what is the usual terminology used to name these different formats of pin arrangement (i'm guessing it's just the usual terms, 10pin or 16 pin, but just checking)
Thanks if you can help
T
You would just go looking for a 10 pin to 16 pin Eurorack ribbon cable. I find this is actually the ribbon cable I run into most - more than 16 to 16, at least. When you buy more modules that are not standalone, they'll often come with this cable, and it will occasionally already be plugged in.
Thanks for this response, I will do that.... i just wanted to check that there are no additional issues to do with compatibility or other factors i needed to know!
With kind regards T
