Hi everyone
I'm a TOTAL beginner with zero knowledge of synths and electronica , so I hope a very, very basic question is OK.
So far I have...
1. a TIPTOP Audio rack with a power supply on the rack - it is this one https://www.thomann.de/gb/tiptop_audio_happy_ending_kit_black_eu.htm
  1. A Doepfer basic VCO A-110-1
  2. A Moog Mavis
I know i can use the Mavis in it's own case, but i want to put them both on the rack
My super basic question is, am i safe to power these two off the Tiptop's power units's ribbon connection without blowing them up
and/or do i need to know anything or adjust anything here?
Thanks if you can help!
Tierno
Power Supply (uZeus 4HP) specs:
+12V: 2000 mA
-12V: 500 mA
+5V: 170 mA
Doepfer basic VCO A-110-1 needs:
+12V: 90 mA
-12V: 20 mA
+5V: 0 mA
Moog Mavis needs:
+12V: 112 mA
-12V: 0 mA
+5V: 0 mA
you can simply sum up those numbers for each power line (+12V, -12V, +5V) and compare it with the numbers od you power supply. it is recommended to not exceed 75-80% of the given power supply
If those numbers are correct (please verify yourself) it is totally safe to use it for your 2 modules. Further you have a lot of headroom for more power hungry modules left...
