I am starting with modular synth and trying to understand bit by bit.
What puzzles modular me now is how to "play" Behringer Wasp Deluxe with eurorack.
I cannot trigger a rhythm or a pitch, I don't find out how to send sequencer gate to Wasp or even pitch it.
Trs to midi does fail on me also.
Any tips?
Greetings
Alex
farkas
What sequencer are you using? What modules are you trying to integrate with the Wasp?
I have a "Tiptop audio circadian rhythms" and a "Erica Synths Black VC Clock V2" to generate rhythms.
After Later Audio - Resonate (Rings), Typhoon, MVMNT, Tiptop audio Z5000 as fx to start with.
farkas
Circadian Rhythms is a gate/trigger sequencer. I don't believe it has either pitch CV outputs or MIDI outs. The Wasp is very limited in its eurorack connectivity, so you will need a MIDI sequencer of some sort, like a Keystep or something to get gate and pitch sequences happening since it doesn't have gate and pitch inputs.
Thanks for this quick reply. I will go completely modular and skip the semimodular synths
You should connect the Behringer Wasp to the ocean, by throwing it into it, dramatically and at sunset, while promising to yourself to support non-shitty companies/products.
