This patch attempts to create the appearance of multiple voices from just one by only occasionally sending a note to the delay. A second voice can be added, tuned to a perfect 5th of the primary voice to add a little more depth.
Before getting started, tune the top oscillator to a C, and the bottom to a G.
The Rene's X channel is used to sequence the frequency of both oscillators. The X channel gate triggers the envelope for the primary voice, going to the dry channel. Use a slower Tempi clock to The Y channel or a more sparse gate pattenrn to trigger a second envelope which controls when the oscillators get sent to the Mimeophon.
For best results, keep Mimeophon clock to same tempo as X-channel, and Rate at noon.
Listen to the result on the output of VCA channel 4, rather than mimeophon like you normally do.
Play with:
- envelopes
- gate patterns on X and Y channels
- clock speeds to the Rene
- Access page of X and Y channels to create sequences of varying lengths
- Mimeophone Zone, Repeats, and Halo
