I wonder if the 207 can individually octave transpose channels.
I know Bard Quartet can ...
I know Ornament and Crime can ...
Can ADDAC 207 ?!
Peace.
Can ADDAC 207 ?!
Peace.
have you tried reading the manual?
https://www.addacsystem.com/contents/productdownload/ADDAC_207_Quantizer_REV05.pdf
theres a section on transposing in it - I only read the table of contents...
If you just take a look at the frontpanel, you'll have your answer.
ambient • electronica • microtonality
diy eurorack & pedal builder • bassist
My music on Bandcamp: https://driesgeusens.bandcamp.com/
Hi both!
It´s not that clear ...
I´ve read the manual but doesn´t appear to allow independent octave transposition accross channels.
There is a octave offset, but it´s not per channel i guess, just an overall transpose of the octaves.
You're absolutely correct, I was wrong. Octave offset and key/octave are shared by all voices.
I've had this one some time ago and thought it could do that independantly for all voices.
Hi both!
There is a octave offset, but it´s not per channel i guess, just an overall transpose of the octaves.-- redsquares
