Can this somehow be patched to be used as a trigger/clock?
Probably the most versatile module of a Serge Modular system, incorporating a wide range of functions for both CV and audio
https://serge-modular.com/serge_eurorack?mod=RS_DSG_EIt can! Simply engage one side to cycle (central switch between rise and fall attenuverters) and you get a cycling LFO/slope. The clock aspect can be used from the left side if you take the "Pulse" output. You can also clock things using the "End" output of either side, but that can tend to be a very narrow trigger. Depending on what you are clocking with that trigger, you could have missed or skipped beats. I had a hard time using the "End" output with a Doepfer clock divider, but never had an issue using the "Pulse" output.
Thank you! I actually manage to figure it out after some time owning the module by using the pulse instead of end, wich was indeed really unstable/narrow.
Glad that worked! It's such a deep module that can do so much. I owned three DUSGs at one point before trimming down my rack.
