Hi
Does anyone know (preferably small) modules that acts as LP and HP filter with a single frequency knob?
noon: unfiltered
CCW: LP cutoff
CW: HP cutoff
Like endorphin.es squawk dirty to me in this mode:
or the endorphin.es - Ghost
Does this type of filter-combo has a special name?
Thank you in advance for any suggestions!
VONDENFUNKEN
https://www.modulargrid.net/e/bastl-instruments-ikarie
Check: Bastl Ikarie
8 HP - LP/HP Filter with Stereo VCA
+ Many features in just 8 hp
Its not orginal a DJ-filter but you can do the same + far more with it
Maybe this could suit you
I like it very much
Greetings
Chris
some of the doepfer filter modules do this in 8hp - wasp, sem etc
farkas
Usually called "DJ" filters. Erica Synths makes one:
https://www.modulargrid.net/e/erica-synths-black-dj-vcf
I have 2 wasp filters but the LP/HP mix knob is additional to the cutoff knob which requires to use both hands in some situations.
unfortuantely the unfiltered signal of the cutoff is on the opposite position for HP/LP (like most filters i have in my rack).
thx anyway!!
...Usually called "DJ" filters...
-- farkas
thank you!
All versions of Happy Nerding - FX Aid seems to be capable as well:
Further Expert Sleepers - Disting MK4 has also a DJ-Filter algorithm:
