toodee
Can anyone using this version confirm it is compatible with Hemisphere please ?
The old hardware I use (1U O&C from Plum, 1st gen) has trouble with voltage ranges in Hemisphere so I can only run the original firmware, and that makes me sad...
Thanks in advance for sharing your experience
Works great with Hemsiphere! ALA also has great support. I accidentally broke mine (I snapped the micro-usb port off on the teensy; completely my fault), and ALA repaired for only cost of part!
That said, Plum has special builds of the Phazerville suite (an actively developed fork of Hemisphere) for the 1u version, so you might try that. The dev works directly with Plum to ensure compatibility, so should work.
toodee
Well, looks like I owe you one !
I had not heard or read about Phazerville before but it does indeed work with my v1 version of O&C 4Robots AND it contains some of the apps of the original firmware - I was so happy when I tried the firmware, I got lost in the test patch and started wiggling filter cut off knobs for an hour.
Thanks, friend, you made my day :-)
