...Maybe I want the Nautilus delay with MI Veils or equivalent.
-- k0s0
I'd almost definitely want a quad cascading vca... veils or a clone is a good choice...
and probably a delay and a reverb...
don't think I'd want the nifty bundle pedals though... they don't have good reputations & are hard to resell...
tbh with the spectraphon - I'd want a bigger case... not enough room for support modules in a nifty case...
take a look at my signature - think it over for a while... then think about the modules you want and need to support it and then pick a case to house them, preferably leaving some space to expand (20% or so at least)
Wow, what a thoughtful reply! I was just making notes to self for future idea.
I got this case as I wanted the spectraphon and did not have any room for this giant in my two cases. Once I have a house, I'll allow myself to buy a large eurorack case and have my "studio" somehwere other than the hall. I decided I really wanted the Subcon Model 52 Vampire . Having recently got a Keystep Pro I realized....that's four voices of polyphony, this could be a tiny mini-system! It was never originally intended that way; it was more just a overflow case that sits near the rest of my eurorack and semi-modular. I already have the Orion phaser too as I couldn't resist a small eurorack phaser and my pedal phaser broke :(
So then I need a quick + dirty way of converting gates to something with a little more shape that can also mix down to stereo.
I've added rearranged this how I hopefully can fill this out after next year's tax season. What do you think? I'm really hoping cloaks + veils + the keystep gates can be "close enough" to an envelope for the vampire + spectraphon voices. In any case, I think it will be fun to play with and will mostly just stay at home wired to my other racks which have a bit more utility modules in them (though one can never have enough maths...sheesh!)
...this is also why I don't buy a bigger case right now....if I get it, I'll just dream of all those modules I don't have that I always meant to get!
-- k0s0
sounds like a plan - sometimes it's hard to tell if people are newbies or not...
good luck wiht the house!!!
Thanks in any case. You helped me figure out where I wanted to go with this rack!
Alright. My initial rack broke (the board fried ... NiftyCase in case you're curious) so I just "had" to get a new rack. So I doubled my HP. The 84 HP on the bottom are, at time of writing, modules I don't have (yet). I really want the Collide 4 so the rest should center around that. I do have other racks (and a KSP, etc) so racks aren't in isolation here but...I do feel a rack should be a musical instrument by itself.
What do you think about my proposed bottom row? The top row I already have.
  • The QPAS is more HP thank I'd like...but I'm pretty sure its the filter I want
  • I found it hard to add enough clock + rhythm to the rack. I'm basically using CLK and the 4ms RCD. Not great, but HP is in demand! I thought about getting Euclidean circles, but its too big and I still need a clock :( If I could just free up 2 more HP... https://busycircuits.com/pages/alm034
  • Never enough LFOs! I do have the Vampire LFO and thought expert sleepers Otterley and Stages/Steps could be as best as I can do for the space I have
  • And I need a drum. Crater was the one I wanted the last time I filled up a rack.
I'm also consider Makenoise channel saver instead of kinks + 2hp dual vca. I always wanted kinks, so this would make me miss it, but am trying to figure out what will make a better rack.
I've been chatting with ChatGPT about this rack and just wanted to save a current "thought":
"To go from “very close” to “something special”:
Stop thinking in terms of modules
Start thinking in terms of roles
Let Collide 4 decide when things happen
Let MISO decide how things move
Let øchd decide how things breathe
You’ve built a rack that can evolve, respond, and surprise you — without being chaotic or unfocused."
