Hi,
I've got a few Roland boutiques that i like a lot, but would like to extend yheor usage with a modular setup. What i have now is an SH-01A, TR-06 and TB-03. For modules i own a Qu-Bit Wave, 2hp Mix, ALM SBG and an Intellijel Plog. Im thinking of getting a Plaits (probably the Knit), but not sure what else ill need / want beyind that. I expect to use the sequencers from the 06 and 03, but suspect I'll need some envelopes and sequencable modulation sources. I also like the Plog for deriving other triggers/gates from the boutiques.
Any suggestions on what might fill out a setup to complement what ive currently got? I'm definitely just dipping my yoes into the modular world and already feel like i should have done more research, so any help is appreciated.
I'd go for a full size clone if I were you.. much better ergonomics, plaits is small enough already, & you get full size knobs which are better for tuning etc...
maybe a Pams Pro would tick all your boxes, envelopes and synced modulation? as well as many other functions...
does the 03 sequencer output 1v/oct? idk...
take a look at my signature & spend some time thinking about it... especially the formula...
for utilities it's almost impossible to go wrong with a matrix mixer! and a quad cascading vca (veils clone for instance)
& you'll almost definitely want to improve your mixing from a 2hp mixer! thats much better
how are you mixing the rolland boutiques & the modules?
Hey @JimHowell1970, this gives me a lot to think about, thanks.
Makes sense about the full size Plaits. I definitely like the spaciousness of the Wave over the tiny dials of my other modules right now.
The TB-03 and SH-01a both have clock in (steps their internal sequencer), 1v/oct output and gate output. The TR-06 has 5 trigger outs.
I will look into some veils clones. At a glance that seems good since it also is a mixer?
For how I'm currently mixing everything I have with a Mackie mixer and so im using the sends for reverb and delay. At one point i was trying to understand if i could just use attenuators to reduce the module output so i could still mix them in my cirrent mixer (this would also let me add effects how im doing it now for the boutique's).
Your formula in your signature confirms what i was suspecting, that just some sound sources aren't going to take me far enough.
NP
you might find that the Mackie is fine without any attenuation - I used to use a Yamaha module without any and it was fine... the Mackie might have a pad feature that could help - if you experience clipping then just get an inexpensive passive attenuator (they'll always be useful) - a 2hp trim would work fine - as it's set and forget - and if you still have problems then you could try the veils clone, and then if you still have problems investigate output modules - I've never had one in 7 years, though
-- sporkandfoon
imo, they're often the least important thing... it's what you do with them and how you modulate the signal path that's important...
have fun!
