I promise I'm not insane. This is my first post but I think I'm onto something:
A fun fact is that if you overload your MicroZeus power supply with too many modules, it may make a high pitched tone. (THIS CAN BE SAMPLED BOYS)
Funner fact: if you almost overload your power supply, that high pitched tone will be produced right when you power up the system, but then quickly fall off as things stabilize. As such I will be contacting modular grid to have the MicroZeus reclassified as an envelope generator
and then I will sample it and turn it into a bassline
don't do this & don't recommend anyone else do this..
you are likely to damage the uZeus...
