wishbonebrewery
If I have a module that has an Accent input and its expecting a Gate or Trigger is it possible to use the Velocity output on the Beatsteo Pro to do this. I realise I could use 2 sequencer patterns but that would take up, you guessed it, 2 sequencer lanes!
Thanks
should work fine... as long as the voltage is high enough and the signal is as long as you want it to be...
if the module's expecting a trigger/gate it's probably expecting a threshold to be reached to apply the accent and a drop below that threshold to stop applying the accent...
not sure how the velocity is done in the beatstep pro - I've never used it on mine - but I suspect that it just outputs a voltage based on the max output / the value of the velocity... and then turn off once the step is over... so effectively a gate at the level specified by the velocity value
shouldn't hurt anyway - give it a try!! - it's all just control voltage
wishbonebrewery
OK, thanks.
Just giving it a go with the Patching Panda Punch and it does something but not as well as shooting it a gate, it seems a low velocity is the default High and a high velocity is a low or reduced accent. Weird.
wishbonebrewery
oops, double post!
ferran_RMBL
Hi,
Through the Midi Control Center Software you can access the velocity damping values of each sequencer (1 and 2).
I leave you a post from the arturia forum that was useful for me to adapt the output range of the BSP with eurorack modules.
Velocity Cv range could be attenuated with the MCC. You can find this parameter in Device Settings, Global section and it is ----named Seq1 (or Seq2) Velocity Scaling.
You can choose between 10 values from 1 to 10. 1 is min range, 10 is max range, no attenuation. When no attenuation (value = 10) velocity range is about 0-12V (0 for min velocity 01 and 12V for max velocity 127). So the 12V are divided by 127 values.
Max attenuation (value = 1) is 1/10e of max range so the output goes from 0V to about 1.5V. 1.5V is now divided by 127values.
You can approximate max output using this formula (ParamValue is your MCC setting) :
Max Output Voltage = 12 * ParamValue /10
wishbonebrewery
Ooo, I'll have to dig into that. Cheers
