I've made a rack full of modules that I think would be good for a beginner for generating ideas. I don't plan on using this rack for anything specific, just to tinker and mess around with. Would this be a good starter? Should I add or remove anything? I'll be getting a case with two rows of 62hp, so I'll have plenty of room for additions.
OK...
1 get a bigger case - small cases are very often a false economy... as you will end up buying another case within a few weeks or months... better to start off with that slightly bigger case - a tip top mantis is an excellend starter case and one of the best bangs for money in eurorack (hp/cost/manufacturer reputation/decent power)
these tiny cases are great for mission specific roles when you know what you are doing, but at the moment neither of these appply to you
  1. how are you going to plqy this? are you expecting to play it via a keyboard or from a DAW? then you are missing the midi to cv module you need... only 1/2 the module is included in the case - you still need the cv output part... Pams includes some random sequence generation, amongst other things (rtfm), but it's likely that sooner or later and probably sooner you'll want to be able to create a sequence - and there's no space left in the case for that... NB there are external sequencers - maybe one of these would be a good idea...
  2. in a case this small there's not really enough space for multiple voices - something will be missing... a filter for the dixie for example... stick to one voice and what's needed to support it rather than trying to do too much in too small a case...
  3. again in a small case there is no space for overlap when not needed - the functionality of the EG can be covered by pams (again rtfm)
I would either just get a bigger case and start with a few modules - a sound source, a sound modifier, a modulation source, a way to play and a way to listen - which in this case may just be Pams, plaits (you'll likely only get a clone - ALA for example), an effect mdoule and a headphone output: Pams covers (to some extent) the way to play and the modulation source, plaits is the sound source (including vca, filter and has some internal modulation based on the envelope sent into the level) etc
OR
ignore the size of the case for now - start with a 9u (or 10u, if you must have 1u) 104hp or bigger case in modulargrid and put the modules you really want in it (taking into account the functionality that you want - ie 2 voices) and try to work out the modules that you need to support those and then show us the result for critique - then buy a case that is appropriate for the modules and leaves 20%+ free for expansion so that you are not going to need to buy another case almost immediately when you see that module that you need a week after you've finished buying all the modules that you think you want and the modules that we've pointed out that you need in order to support them properly
and take a look at my signature... spend a decent amount of time thinking about it and how it applies to you and the modules you think you want...
Sweelinck
For an external sequencer, regardless of the size of your setup, BeatStep Pro is a great solution.
In the meantime, and about sequencing melody with Pam’s Pro, see that video at 5:17
indeed it is! and it's a keeper - ie it's always useful no matter how big your rack gets to... currently I predominantly use mine for sequencing song part/chord progression changes on my sinfonion - clocked from the sinfonion...
