AEROCATONE
Any good ideas on how to plug these holes? Every few rows of my rack has one, it "seams"
Anyone know any 1hp modules or panels?
I don't want the space clowns to escape through the cracks.....
over:under
Im assuming you want 3U, correct?
doepfer amongst others make them - available at most modular stores worldwide... for only a few $/€/£...
although 1hp gaps aren't that bad (screws can get in but patch cables probably can't) and can be helpful with regards to cooling...
AEROCATONE
-- danlegg
Yes
over:under
I would suggest using 1HP blanks if you dont want little exposed gaps as there are no particulary usable modules that I can think of, which are that small.
Here are some honourable meantions for 1HP blanks
https://www.modulargrid.net/e/fully-wired-electronics-1hp-blanking-panel (Fully Wired Elecronics Store - https://www.fullywiredelectronics.com/product-page/1hp-blanking-panel-3u)
https://www.modulargrid.net/e/make-noise-1hp-blank (Thomann - https://www.thomann.de/de/make_noise_1hp_blank.htm)
https://www.modulargrid.net/e/doepfer-a-100b1 (Thomann - https://www.thomann.de/de/doepfer_a_100_b1.htm?ref=search_complete_a%20100b1_suggestion_products%20-%20Doepfer%20A-100%20B1_Doepfer%20A-100%20B1_0)
That said gaps are of course useful as venting
wishbonebrewery
1hp gaps are good for back-routing clock signals around the case.
1hp gaps are great between 2hp Modular Modules.
Ventilation is good.
AEROCATONE
BRILLIANT!!!
over:under
-- wishbonebrewery
But what about the space clowns?
Sweelinck
I use RackBrutes. They’re supposed to have 88hp per row. They actually have 89. I always leave the extra 1hp for better ventilation.
And against space clowns... I have an adorable (fawn) pug and five cats (including two black cats, @wishbonebrewery ;)
Otherwise, I don’t know what it’s worth, but there is also this: https://www.modulargrid.net/e/konstant-lab-pwr-checker
wishbonebrewery
I find there are enough Space Clowns outside my case noodling so having more inside the case would be overkill, I'm never sure of the current draw of internal clowns either.
Are they why everyone says get a bigger case?
Arrandan
Don't forget the Wackel Kontakt! It's a 2x4 multiple but who knows if it will work?
AEROCATONE
-- Arrandan
OMG! Problem solved.
Space Clowns rejoice!!!
over:under
Arrandan
-- Arrandan
-- AEROCATONE
I got one for free with another module. Obviously, the Wackel is my favorite module ever! And I haven't even used is as a multiple yet!
