Loersatz
Hi all,
Second post here.
Just a question as stated above. I have contacted ModBap weeks ago but no answer from them. Maybe someone knows.
Here it is: while using the 2 separate outputs on the Osiris, (one for the voice and the other for the sub OSC), I get a non stop sub out even when stopping my sequencer. Output is connected to a separate input on my mixer (4ms Listen4). I do understand that the sub out gives a full volume, which is not a problem as I can tame it down with the mixer.
The weird thing is that when I hit stop on my sequencer, the sub out keeps delivering its full volume out. It will only stop on a double press on stop on the sequencer. MORE: when double pressing stop on the sequencer, I still get a signal (audio?) coming on my mixer (4ms Listen4). I do not hear anything but it looks like something is still coming out. Confirmed by the fact that I get the same visual signal on the A/B inputs on my Octatrack. Same as the 4ms mixer.
Any idea?
Thanks for any hint in advance, much appreciated as ever,
Olivier
"I've seen things you people wouldn't believe... Attack ships on fire off the shoulder of Orion. I watched C-Beams glitter in the dark near the Tannhäuser Gates.
All those moments will be lost in time, like tears in rain. Time to die..." R. Hauer
Hi,
Sounds like a normal behaviour for me.
The sub out of the Osiris acts like a classic VCO and not like a synth voice : it's playing the sound continuously and is not affected by the decay knob.
You have to pass it thru an enveloppe + VCA combo.
Cheers,
Cédric
Loersatz
Hi Cédric,
Thanks a lot for your help. I was expecting it to be this.
When you say "You have to pass it thru an enveloppe + VCA combo", could you detail the actual connection?
Should I just output the sub OUT to an EG (I have a pip slope mk2 at the moment) through its gate or trigger?
And then to the VCA?
Thank you very much for the help, much appreciated.
Had a glance at your 416 rack and there is a lot of the same I am looking at (Voltage Block for instance).
Best,
Olivier
You're welcome !
The exact connection would be :
Sub out > VCA signal in
EG out > VCA CV in
VCA signal out > mixer
(You Can also find EG with integrated VCAS, like WMD Javelin, Cosmotronic Delta V, or the latest 4ms that looks dope !!)
You'll also need a trigger or a gate to start the enveloppe.
The role of the function generator here is to modulate the amplification of the audio signal going into the VCA.
Imagine a volume curve if you like.
Once the enveloppe is not triggered (sequencer stopped) your volume will stay to zero.
It's also interresting to put a low pass filter (vcf) between VCA and mixer.
Then you can modulate the filter with the same enveloppe (with a multiple) to give more dynamics to your bass sound ! :)
Hope it's clear, it's one of the tricks, but some folks here could give you many others.
I'm not a modular expert :)
I highly recommand voltage block ! ^^
Mimetic Digitalis is a very good option too, in reduced spaces.
Best,
Cédric
Loersatz
Thank you very much Cédric,
Very kind of you to have taken the time to detail all this.
I am actually using a Mimetic Digitalis (with Lapsus OS) and really like it.
Hoping for a Voltage Block to restock as it is impossible to find one.
Really appreciate all the tips as I am only starting with modular.
Having a blast :)
Best,
Olivier
