Hey ! I’m waiting my command ! So I have a ghost , a sofia and an ADSR. If you have a piece of advice about appoint Out , or rythm and frequencie quantizer for techno progressive , I m really interested
ClemBmusic
a quantizer is a quantizer - intended genre is irrelevant - just like most modules - genre is what you make of it...
how many channels do you want?
an output module may or may not be needed - what are you intending to use for monitoring? an outboard mixer, headphones, powered monitors?
I could to take between 4 and 8 Chanel to be large , ideally I want to sync my desktop studio with the modular patch
ClemBmusic
there are quite a few quantizers that have 4 channels - Bard Quartet, ADDAC, O&C but not many that will handle 8 - sinfonion, perhaps, but that'll only actually quantize 3-4 channels and generate v/oct for the others...
to be clear this is for pitch (v/oct) quantization only...
time quantization is not really done in modular - usually we use clock dividers and multipliers fed by a steady clock to trigger events at precise points - dividing a fast clock will always be more stable than multiplying, as a divider just counts the clock, whilst a multiplier has to measure the time between 2 clock ticks and then divide that time by the multiplication factor (and if the clock is not so stable it will be off at some point
it's more common that people want to add swing or go slightly off clock to humanise the rhythm - using a vc trigger/gate delay, perhaps
I think it might be a good idea if you created a rack on here and shared it (and also the other studio parts you want to interface with)
With pleasure i built my rack but I cant share it , just a jpg . Is sharing possible to suscribe Unicorn ? It could to be That ? https://cdn.modulargrid.net/img/racks/modulargrid_2193237.jpg
ClemBmusic
make the rack public in edit rack and then copy the url and paste it into the post....
ModularGrid Rack It should be start
ClemBmusic
ok so maybe you could add some of the things that you think you want and then we can critique that and add the things you actually need
here's a few hints - you may want and you will need some of the types of modules mentioned:
to connect to your other studio bits and pieces - a midi to cv module (and possibly a cv to midi module) or something like a expert sleepers es8 or 9 - neither of which will require quantization as the output will already be quantized - possibly to talk to a computer/DAW
possibly a sequencer - which may or may not include a quantizer - you may want more than one of these - possibly a trigger sequencer and a melodic sequencer for sequencing pitch (v/oct) and possibly gates
a quad cascading vca - I lik veils - clones are available - as it has enough gain to be also used as an input module if needed (most vcas do not have this)
an lfo - probably multichannel
a function generator - I like maths, as it has the best documentation, particularly the 'maths illustrated supplement'
a mixer (for combining the outputs of the oscillator)
a mixer for combining modulation sources (I like matrix mixers)
an end of chain mixer - to combine different sounds and output to ? headphones/mixer/monitors?
possibly an input module - so that you can amplify external gear to modular levels
some utility modules to help you copy signals (muult) and modify them
Sweelinck
On this page you will find information that will surely help you: https://www.modulargrid.net/e/forum/posts/index/10775
-- Sweelinck
Thx !!
I have Several deeadbox (nyx HADES erebus v2)
Excellent idea , is a drum séquencer like Drumbrute impact could to pilot ? Or minilog matrix were percer too
Added on my rack
a multipl chan LFO black noise added but LOWER game ,
a function generator - ?'
ClemBmusic
-- Sweelinck
Thx !!
Added on my rack
https://cdn.modulargrid.net/img/racks/modulargrid_2193237.jpg?1678630225
ClemBmusic
and now the actual link!
ah good the thumbnail doesn't match - but not a problem...
the midi-cv module appears to be discontinued... may be impossible to source...
the sequencer is I believe very difficult to get hold of and probably not the easiest to get to grips with...
mixer ok...
no vcas... not enough channels of lfo/function generator!!! you will need these!!!!
Okay , I havé something now, Sounds better like that ?
ModularGrid Rack or ModularGrid Rack (Wait for update .m’a)
ClemBmusic
Maybe some reasoning for your selections would be in order...
why the battleship sequencer without enough voices for it to drive?
why the knobula? do you know how you could use it?
why no submixers?
and most importantly why no VCAS????????
Maybe this can help... Or... Maybe not...
https://modwiggler.com/forum/viewtopic.php?t=230155
-- Dub007
that's quite a good idea!
Trank you for the Link this bible explains what thé LFO/VCA with multiples is very important .
So Math seems to be the référence : is there a same quality alternative ? And iahve you a Good réf• Midi to cv ?
Cheers
ClemBmusic
midi to cv you might want to look at the cv.ocd or if you want it in the rack erica synths are now making the mutant brain
Maths - best Maths substitute is Maths - simply because of the numerous videos on youtube and the fucking fantastic "maths illustrated supplement" - why is it so fantastic - because aside from giving you 32 patch examples for Maths - if you think hard about what, why and how maths and the patching is working it will serve as a jumping off point for all your future patching - what if I do this, how do I do this, why an I doing this?????
there are many other similar modules - designs based on the serge dual universal signal generator - but Maths is by far the most popular and in many ways the best - not least the ergonomics are good and the configuration - 2 function generators, 2 attenuverters with offsets, a bit of mixing (including a negative output) and a bit of logic are enough to kick start an entry level modular...
& don't let the name 'maths' put you off - you are after all designing/building yourself a customised, analog computer that specializes in generating sound - ie a modular synthesizer
Okay …. So next command Will be Math••• to the VCA/LFO for Numbers or examples and tutorials.
Mixer - Cosmix
ADSR - not decided (vca with multipl ?) lost ans no decided
Cv/midi : lost and not decided
Séquencer ‘ perhaps à Berhinger ? Or to wait and be patient for next month ;)
ClemBmusic
If it was me:
Maths yes
Mixer - Cosmix
I'd hold off on this for now - but do get a quad cascading vca - a veils clone if possible (Big T music) - it will act like a mono mixer for now and a midi interface or a sequencer is a better buy for now
Maths will provide envelopes!!! - not adsr - but adsrs are less common in modular than you'd think - often AD is fine and Maths will give you 2
either one of these - ie erica mutant brain (nb used to be hexinverter electronique) OR
-- clem75Paris
a sequencer - would wait and buy one you actually want rather than a 'cheap' one just to have one - this applies to all modules
