Very interesting! using four identical modules as a Mixer
-- RaymondHu
Thanks. 2x stereo strips are used for my voices (2x legion thru Steiner VCF as a complex osc for bass, CI thru SSG for melody) and then the other two are used for external gear like drum machines etc because they have pre amps for inputting line level gear. The NE stereo mixers are for delay and reverb sends (stack cables from the stereo strips go into them). Everything is then summed by the ES-9 so you can jam live while recording all the tracks separately. You can also have per-channel side-chain by using time warp as an envelope follower, inverting and offsetting the output with OSD and then inputting that signal into the stereo strip vcas on every channel that you want the side chain to apply. This all took a lot of figuring out but it works incredibly well
