It appears the developer has lost interest and the firmware may never see another update or feature enhancement? Since it's open source he has no profit motive to maintain it.
-- mntbighker
if it's open source then anyone should be able to fork the firmware and maintain it/add features...
-- mntbighker
The question remains if anyone ever will.
-- mntbighker
I volunteer you... you seem concerned about it... so maybe you should do it
I'm not a programmer.
-- mntbighker
you could learn, it's not rocket science - and the code's already written
mikeleebirds
I wish I had the time to learn to code, but simple as it may be, I don’t..
ferran_RMBL
I'm a developer, and even if you have the knowledge, it is not an easy task to modify the code written by another, especially if that other person is the creator of the Hardware. Anyway, if it's a small change, don't be discouraged and get your hands on it.
It is difficult or even impossible to break the hardware through code. It is more dangerous to manipulate the hardware.
I am a programmer...
-- ferranadsr
me too...
I took a look at the code as well... it looks like a bit of effort to get into, but only because there's quite a lot of code... it doesn't look that difficult (clean code with meaningful names and nicely laid out) once you do and know the basics of programming/C++... in other words probably not much more effort than it would take either of us - or any other programmer, for that matter
all programmers weren't programmers before they became programmers - you have to start somewhere!
I suspect everyone using this forum has the basic skills needed - reading, googling, high school level maths and typing
mebitek
here a custom firmware: https://github.com/mebitek/performer
here the improvments:
- Extend retrigger value. max 8 retriggers per step
- Extend probability steps. min value now is 6.3%
- add negative gate offset feature
- add metropolis style sequencer option
- double click to toggle gates when editing layers other than gate
- do not reset cv outputs when clock is stopped
- add various curves
- use random seed each access to random gen layer
- add curve improvements
- add midi improvements
- add noise reduction
- add track names
- add quick tie notes feature
- various bugfixes
- improve solo perform
- launchpad follow mode
- launchpad improve slide visulazation
- launchpad color theme
- launchpad circuit dstyle note editor
hope you can test it and reports bugs or feature requests on github
Electronic music/video producer and composer.
Dark Ambient Cinematic atmospheres from Sardinia.
mebitek
new release!!! v0.1.48
https://github.com/mebitek/performer/releases/tag/0.1.48
  • Moving steps in a sequence
  • INIT by step selected
  • smart cycling on patter follow modes (check if launchpad is connected)
  • Show launchpad settings only when a launchpad is connected
  • Apply random for selected steps only
  • double click page to enter context menu for 2 seconds
  • Prevent very short output clock pulses at higher BPMs
  • Undo function (alt+s7)
  • Curve mode backward run modes play reverse playback
  • Bypass the Voltage Table in specific steps of the sequence
as always, please open issues on github and share your experience with the custom firmware.
don't forget to rate the project to gitub!!!
enjoy
mebitek
Hi all,
I proudly present version 0.2.0
https://github.com/mebitek/performer/releases/tag/0.2.0
  • Stochastic Track
    • global octave modifier
    • launchpad control general octave
    • loop and lock loop
    • reseed
    • rest probability 2,4,8 steps
    • global gate length modifier
    • clipboard actions
    • generators
  • Load/Save Sequence to use a sequence library (fast switch on loading)
  • Launchpad Performance Mode 8+3 (2+GRID2 -> quick set lenght sequence; 2+GRID1 -> overview page )
  • Submenu shortcuts (double click F[1-5] to enter project, layout, routing, midi out, user scale)
  • Page buttons on launchpad circuit note edit
  • Extend gate Lenght to 4bits @glibersat
  • Multi Curve CV Recording (cv curve input has been moved in track page)
  • quick change octave shortuct (step+F[1-5]) 1-5V
  • quick gate accent launchpad control on gate page and circuit page (7+GRID)
  • add steps to stop feature in project page. Once started when the engine reaches the steps to stop value the clock will stop.
  • improved overview page. quick edit tracks
you can find full documentation here:
https://mebitek.github.io/performer/manual/
as this releases contains lot of new features (over all the new stochastic track) please open issues on github. I will not implement new feature requests until the current 0.2.0 version is perfectly stable.
thx to testers:
Guillaume Libersat, Nik Ansell, XponentOne, Blueman Gil Arts, hales2488, Matteo Chiarenza Santini, KittenVillage, Andreas Hieninger
and thx to all who made donation or bought my music to support my work on the beautiful Westlicht PER|FORMER eurorack sequenceer
mebitek
Version 0.2.2 is out:
https://github.com/mebitek/performer/releases/tag/0.2.2
Logic Track
fix shift steps feature -> Guillaume Libersat
step recorder "move step forward" shortcuts
step recorder "current step" cv routable, respond to gate (5ms)
curve track cv contrallable min and max
Overview page improvements
add trigger curve shape
add filter note parameter
thanks to the greatest tester team ever: Blueman Jil Arts Pompeius Magnus Lenneskog Andreas Hieninger
full documentation: https://mebitek.github.io/performer/manual/
feel free to open an issue on github to report bugs or open a discussion to share new ideas
remember to rate the project on github and if you want just make a donation to support my work
mebitek
Hi all,
finally release 0.3.0 is available!
- Arpeggiator Track
- increase stochastic rest proability to 15 steps
- logic track fast input visulaization (press shift)
- fix clipboard copy track
- fix logic gate probability
- fix rotate steps (thx to glibersat)
- keep sequence names when copy and paste
- issue #100 - reorganize quick functions shortcuts
- issue #101 - reset cv in stop parameter
- integrate Malekko integration
https://github.com/mebitek/performer/releases/tag/0.3.0
from now on there will be no more major upgrades but just bufixes and workflow improvements. feel free to open issues on github both for bugs and for workflow ideas.
as always rate the project on github and feel free to donate to support the project:
https://mebitek.bandcamp.com/
https://liberapay.com/mebitek
thanks to all tester Jil, Guillaume Libersat, XQSTKRPS, P.M. Lenneskog
Hi, alternative MEBITEK firmware
Vinx77
Vinx PER|FORMER firmware – update v0.4.0
https://vinxscorza.github.io/performer/
Performance-focused and exploratory.
The idea is to make the PER|FORMER feel more playable in a live context, while still keeping it open to less predictable workflows. What I’m aiming for is a solid machine for live performance, but also a crazy one for experimentation. The goal is not simply to add more options, but to push the PER|FORMER toward stronger creative generators, safer destructive workflows, better live interaction, and a more complete and well-documented ecosystem.
