The vactrols used are really slow, if you are looking for fast response times this is not the module for you.
Voltage controlled vactrol distortion/overdrive with LED limiter
https://synthcube.comThe vactrols used are really slow, if you are looking for fast response times this is not the module for you.
Hey David! If you want a snappier Optodist we recommend the SR3 vactrols, the SR2 are a bit slower which some prefer. Cheers, Ben from RYO
