I've been wanting to get into eurorack for a very long time. I own four semimodular synthesizers, a beatstep pro and sq1, and even bought a Behringer CP1 A months a go because i found it very cheap on eBay which I havent touched at all.
My goal:
I want this rack to be focused only one thing, and thats glitchy percusive/drum sounds. I'm not interested in creating a basic 'kick snare hat' sort of drum machine since I already have a Digitakt and RD9 for more conventional drum sounds. What I really want is to be able to explore sound design but in a rythmic way, both in terms of sequencing and sound modulation.
Influences:
I will list some of the artists that inspire me in order to give a clearer understanding of the sound I'm trying to achieve: Aphex Twin, Floating Points, Jean Jelinek, uZiq, Squarepusher, Venetian Snares, etc...
Context:
I already have a Neutron and DFAM, also I will be using my Beatstep pro as the main sequencer (which has a probability function and can kind of work as a basic 'generative' sequencer). I want to start with a 6U 104hp case in which I want to put both Neutron and DFAM and I'll just remoove them as I get more modules.
The rack I've planned:
https://cdn.modulargrid.net/img/racks/modulargrid_2155174.jpg
Questions:
- I want to bring effects in and out at random times. Would Pamelas New Workout combined with Twiigs allow me to send random clocked gates to the mix inputs of the effects I've put in the rack?
- One of the most important effects I wan to have is a beatrepeat which would allow me to modulate the lenght of the repeats triggered randomly at clocked intervals. Would Databender be able to do that? Are there any better alternatives?
- I have not included any VCAs, envelopes or utility modules, this is becuase the three voices I have in the rack already have built in VCAs and envelopes, plus the Neutron has two attenuators, slew limiter and a basic sample and hold. Am I missing something important here? This is the first time I build a eurorack synthesizer and I'm worried that I might not even know what I dont know.
- Is it absolutely necessary to have an output module? I've seen a lot of people on youtube mixing eurorack signals with outboard mixers and not getting a lot of noise. My idea is to mix all the voices with the STMX module, then send the output into Databender as a final effect and then from Databender straight into my Mackie CR-1604 mixer. Would I be ok doing that?
I know this is quite a long post, but like anyone else when starting with eurorack, I have a million questions haha, also I have watched all of Grant Boss's videos on youtube a million times, and pretty much I want to be able to do what he does but in a waaaaaaaay smaller case.
Thank you very much if you actually took the time to read it, and obviously any feedback is more than appreciated.
Data bender is nice but you may want slice by 2hp as well.
I’m relatively new to this myself and have similar interests. I love the data bender. (I’ll let someone else tell you that you need more vcas lol)
Not sure about running straight out of data bender though. I got an HPO from alm busy circuits for a cheap stereo out. Hope this was useful, Good luck!
ferran_RMBL
I think the mixer/out module has to be the last one in the chain. If you add an effects module later I don't think you can ensure that the output level is not too high for the input of the console. Taking into account that the effect modules usually add feedback, increasing the level of the output audio. I don't know that table or the effects it can cause on it apart from saturating.
farkas
My goal:
  • One of the most important effects I wan to have is a beatrepeat which would allow me to modulate the lenght of the repeats triggered randomly at clocked intervals. Would Databender be able to do that? Are there any better alternatives?
    • I have not included any VCAs, envelopes or utility modules, this is becuase the three voices I have in the rack already have built in VCAs and envelopes,
-- Adrian97
I would recommend looking at Qu-Bit's Prism along with the Data Bender. I have both, and get more controllable/predictable beat repeat style effects from Prism. I love Data Bender, but it kind of does what it wants, and it's much more glitchy. It takes a little work to make it "musical," and if you aren't planning to add more utilities/envelopes/etc. (which you absolutely should if you want to get the most out of modular), you may find yourself a little frustrated with it. I've found that Prism is pretty awesome for a Warp Records kind of vibe.
Have fun and good luck!
obscuremachines
Have been down this road before. If you don't have Mito you should check out this module by Robotdogmusic the Improbable Sequence Generator
cheap is not often associated with good... the b-company power supply is almost definitely not powerful enough to power the 6u 104hp case you envisage - just checked and you've got 2 - might work... remember the semis will want power and you need to leave at least 25-30% headroom on each rail
My goal:
so in my mind that would be oscillators, vcas, envelopes, lfos, filters and maybe an effect module or 2
Influences:
Context:
I would have helped here and posted a link to the url of your actual rack... but I couldn't be bothered to sift through 8 racks to find the right one... jpgs are shite...
Questions:
I'd tend towards Pams Pro Workout as this will probably allow you to do this in a single module - and use envelopes not gates
worth looking at: clouds clone with the kammerl beat repeat firmware... you'll probably want attenuators for modulation
  • I have not included any VCAs, envelopes or utility modules, this is becuase the three voices I have in the rack already have built in VCAs and envelopes, plus the Neutron has two attenuators, slew limiter and a basic sample and hold. Am I missing something important here? This is the first time I build a eurorack synthesizer and I'm worried that I might not even know what I dont know.
are the vcas, envelopes and other fundamentally important utilities patchable and still usable in the semis? I doubt it... think again these are all fundamental sound design building blocks... you probably want a lot more of them, not less
  • Is it absolutely necessary to have an output module? I've seen a lot of people on youtube mixing eurorack signals with outboard mixers and not getting a lot of noise. My idea is to mix all the voices with the STMX module, then send the output into Databender as a final effect and then from Databender straight into my Mackie CR-1604 mixer. Would I be ok doing that?
it is not necessary to have an output module... but it really depends on whether or not whatever you are sending it to can cope with modular levels without clipping
s0, it will probably work.. but as @ferranadsr said I wouldn't want to go straight into an outboard mixer with the output of an effects module - a more fully featured mixer with a send/returmn facility would be a better idea...
this is probably unrealistic... you may be able to achieve a small subset of what he does, but generally people have large cases for a reason... one of which is being able to run multiple voices and effects chains at once - which you won't really be able to do in a small case
obscuremachines
"this is probably unrealistic... you may be able to achieve a small subset of what he does, but generally people have large cases for a reason... one of which is being able to run multiple voices and effects chains at once - which you won't really be able to do in a small case"
I would have to politely disagree here as far as size of case goes cause you can achieve this sound with a relatively small setup
-- obscuremachines
disagreement is good!!!
Don't forget the Mystic Circuits IDUM! Might come in handy :)
T0MMI001
beat repeat: modbap per4mer
