Hi friends,
I'm looking for a eurorack module (or any simple thing) that would allow me to send through midi a CV master clock (from my euroracks modules) to some guitar pedals (Meris, Hologram etc) to sync. In other words, I don't need to send CC messages – only the start, stop and tempo info of a master clock.
Does that exist ? I seem to see all the modules allowing a complete transfer of CC messages, but I have not found anything that can just produce a master clock from CV to midi (TRS or DIN). Thanks for your help!
It might be overkill, but the Westlicht Performer does that. I use it all the time to sync my modular to my Boss RC-5 Loop Station.
Thanks but it's overkill ! Looking for simplicity..
Still overkill, but it seems like Befaco CV Thing will do Midi clock
https://www.modulargrid.net/e/befaco-cv-thing
Too bad the VPME.de trig31 doesn't seem to do Midi clock. Just the right amount of kill otherwise.
https://www.modulargrid.net/e/vpme-de-trig31
Or set and forget a Disting Mk4
User left
If you ever have considered to dive into the world of micro controllers (Arduino) this would be a great real world use case for a tiny project.
In case you're interested i can send you a few links to my projects where reading cv clock/reset and sending midi clock already exists.
Of course its a lot harder than buying a finished device - but you will learn a lot and maybe inspires you to create other unique stuff with midi + cv signals.
So I was missing something ! Thanks a lot, the Disting Mk4 seems to be for me... (diving into Arduino would be super great.. but I've no time in my life for that..)
-- patchable
Always convenient to have a Disting laying around whenever you need (x)
geusensdriesmusic
deleted
ambient • electronica • microtonality
diy eurorack & pedal builder • bassist
My music on Bandcamp: https://driesgeusens.bandcamp.com/
geusensdriesmusic
Don't know if you're using PNW, but the expander has midi clock out. I'm using a Blokas MidiHub to route clocks etc to pedals, drumboxes, sometimes a DAW... You can filter out anything you don't need your pedals to receive, merge incoming midi messages, use clock dividers, manage midi channels etc. Really powerful little box!
Hi friends,
-- patchable
...I'm using a Blokas MidiHub to route clocks etc to pedal...
...Really powerful little box!...
-- geusensdriesmusic
Yeah - this box seems to be really powerful! But maybe a bit overhead for this use case.
If you are already on the MIDI side of the task a cheaper (and passive) solution for filtering MIDI messages would be the Miditech Midi Thru 4.
I have 2 of those in my non-eurorack-setup and never experienced any problems with it.
