I would describe myself as a hobbyist noisemaker, never a musician.
I've got a standalone Behringer Model D, and it's very fun to play with. I just got a LaunchKey Mini and its MIDI out cable. This enables me to not need a computer/midi-host.
Now that I'm enjoying my synth computer-less, what's a good way to get some stereo delay and reverb, and also a stereo headphone jack output? (I'm not using speakers, so 1/4" outputs are not needed).
I was thinking maybe an effects module (such as Mutable Instruments Beads/Clouds) plus an "ALM019 - HPO" could do the trick.
I could make my own wooden box for these, but then I'd need a power supply. Should I get a eurorack power supply/bus and just use that, further complicating something seemingly small? I'm not yet ready to take the Model D out if its box, but perhaps I could tap it's power supply?
Any suggestions are welcome!
EDIT: I forgot the title, perhaps such a box already exists? I'd love to hear about it!
unless you really want to commit to eurorack (which, be warned, may tie up all your disposable income for years) then you may be better off with a smallish mixer that has built in digital effects - it's possible that one of these may also work as an audio interface, which would be a bonus
modular effects rack = modular synth where the sound source is external
still need to think about modulation sources and utilities... so make sure you leave space to expand into in the case whatever you buy...
clouds cries out for at least a couple of channels of modulation sources - possibly one or more lfos plus random or chaotic - and attenuators or attenuverters as a minimum
beads has attenurandomisers built in, but would still benefit from lfos
wooden boxes are easy - buy rails & threaded inserts though - they make life much easier & make bigger than you think you'll need - 6u 1-4hp is a good starter size
& yes you'll need a power supply - I like befaco excalibus which is available built or as a kit
as the model d has a powered case already I'd keep it in there... taking it out ans putting it in a larger case is a waste
In your situation I'd just get a couple of effect pedals and a small mixer. There are loads of great reverbs, delays, etc, and a good used market. Modular is like stepping into a whole minefield that might be more complication than its worth for you.
This is exactly how I got into modular, although my entry-drug was a Neutron. I thought a MI Clouds would satisfy my effects needs, so I got a Behringer Eurorack Rack (includes a power module) and stuffed it into my 19"-studiorack. Another filter would be nice, I thought. So it started ...
Well, as Jim said, several modulation and utility modules later the rack was full and I built a 6u 104hp-case out of beech wood, screwed some rails into it and continued my journey. And yes, it's expensive, but there are ways to keep the budget reasonable. Always check the classifieds, get clones where it's possible (and ethically justifiable) and think about DIY.
