Hello fellow wigglers. I currently have the ALM mmMIDI module and I am thinking about swapping it out for the Hexinverter Mutant Brain. What I would like to do is use my external gear (Novation BassStation and Erica DB-01) to create arpeggio patterns and then send those patterns to my modular system. Would the Mutant Brain accomplish this?
if the external modules can output arpeggios via midi then yes - all the mutant brain does is convert midi to cv & gates
you will probably find you want/need to use a midi merge box of some sort so that the outputs from both external boxes can be combined before being sent to the midi -> cv inteface
Thanks (again) Jim!
Thanks (again) Jim!
-- isolatediguana
Hi, check out the fh2 from expert sleepers
I was thinking about a mutant brain but finally bought the fh2 2 day ago :)
The brains IS only 4 CV and many trigger.
The fh2 IS 8 CV or Gate out. I think IS better for your use (and got many features)
