Glitched0xff
Hi dears
I'd like to record my session and experimenting with ambisonic and audio360.
My setup is eurorack modular (from vca out ti mixer), model-d and some DIY stuff. All mix with xenix1200fx
I'd like record every instruments in differenti traks.
What is a good solution on budget for recording?
Is Better an USB mixer like ZEDi-10FX (anybody use it?) or a sound card?
Thanks and synth the world
Arrandan
I use an ES-9 to send everything to my iPad, where I use AUM to mix it. AUM can also add effects, side chain compression, etc, so I'm finding it very flexible. With it, you can record each track separately. I also send everything to a mix bus, on which I apply a final EQ (removing hiss if necessary, for example), and I record that as well for publication.
