Is this one the right power brick ?
for
http://www.eowave.com/modular-cases/3u-black-powered/
This case is shipped with a 1.66A PSU and I need a 4A PSU
Thanks fam,
PCHMR
for
Thanks fam,
PCHMR
	That should work, the only thing to double check is whether the 5.5/2.5mm DC jack connector is the right size for the case. Even if it's not though you should be able to find a cheap adapter.
	I talk with someone who say its 2,1mm... and an adapter will cause bad contact... I can't find a 2,1mm on internet argh...
