Are there any chaos modules that have the ability to go from LFO rates to audio rates "smoothly"? Ideally with some kind of semi-controlled rate knob like in the zlob Diode Chaos. Diode Chaos almost gets there but it barely touches audio rate and doesn't seem to have a ton of room on the knob for exploring up there.
I could do this with a lfo/oscillator like the Pittsburgh oscillator and a clock-based chaos module like the NLC Squid Axom but then the rhythm would not be chaotic, only the voltage.
Hello,
I'm not sure if this is exactly what you're looking for, but maybe check out Joranalogue's Orbit 3:
https://www.modulargrid.net/e/joranalogue-audio-design-orbit-3
This is from the manual:
"...with a range of 22 Hz to 22 kHz in the audio frequency mode.
In low frequency mode, the total range is
2.4 mHz (a period of 7 minutes) to 180 Hz, with
1 Hz when the knob is centred."
In other words, Orbit 3's LOW mode can get you into audio rates (up to 180 Hz), but I don't know how that compares to Zlob's module and if that is an improvement for your purposes.
wrecksmoondee
-- prester_john
Check out the Ian Fritz Hypster from Nonlinearcircuits: https://www.modulargrid.net/e/nonlinearcircuits-ian-fritz-s-hypster
Thank you both for the replies. The Orbit in low mode goes a little further into the audio range than the diode chaos but it's like using a nuclear bomb to shovel your garden for my purposes. And it still doesn't go as far into the audio range as I would like. I find that's the case with a lot of oscillators and stuff with lfo/audio rate switches too.
The Hypster seems just about perfect, relatively speaking. Neither of the colorfully named knobs are secretly a range knob, are they? I haven't been able to find a demo that shows how low/high it can go and the documentation is a little sparse.
wrecksmoondee
The knob named "rate" is the one some might call "range" in secret. What documentation there is saya that it goes from approximately 3kHz down to 5 minute orbits. Ian Fritz told me that negative CV will slow it down even further. Perhaps it can be driven even faster too, but I didn't ask... Really cool circuit anyway :)
Wow I meant to say switch, not knob.
That's quite the range, seems pretty perfect.
sibilant
I have a Hypster and love it.
But I also have a Timo Rozendal Ian Fritz Jerkster - Chaotic CV Generator, and it is also a worthy option to consider. It's also just 6 HP. Mind it is DIY, and as I don't have DIY skills, I found a builder to assemble the module.
https://www.modulargrid.net/e/timo-rozendal-ian-fritz-jerkster-chaotic-cv-generator
I personally liked Joranalogue's Orbit 3:
https://www.modulargrid.net/e/joranalogue-audio-design-orbit-3! And so I have constant business in the clinic for cosmetic surgery here for plastic practice!!
