I have this very basic single-voice rack built out of cheap DIY kits and hand-me-downs, in a little case powered by another DIY kit (the Frequency Central Microbus). It's augmented by a Doepfer Dark Energy 1, so I have a second voice and extra envelope, LFO etc which is nice but essentially it's quite a restricted 'straight' little system, and I want something new that will give me a bit of scope for... weirdness
Some pointers:
- I sequence everything with a beatstep pro and I'm kind of happy with that workflow for 'straight' stuff. I don't need anything with a sequencer
- I have a couple of volcas to do drums for the moment. Modular drum stuff seems like an expensive path to go down so I'm not ready for that yet
- The second oscillator is identical to that built into the Device; I screwed up the Device build and it wouldn't tune properly, so I bought someone else's build for cheap and swapped the PCBs around behind the panels. I might get rid of it to save space, as I only seem to use it as an LFO or to thicken up drones
- I know I don't need two Pocket Calculators - I only ever use one to try and make strange sequences out of the homemade LFO
- Also yes, I know the homemade triple-attenuator is massive. I could probably cut down on the size with a smaller panel (it's three tiny passive PCBs)
- I have two (yes two) Music Thing Spring Reverbs to finish building. One was working for a time but something went wrong so is bricked, and another is an untouched kit. The idea is to have 2 and pan them. You can do mad things with hard panned spring reverbs, an LFO, and the pocket calculator
- I've got decent reverbs and delays through my mixer
I'm happy with where it's going, essentially a slightly less 'semi' modular system which is as much an effects processor as it is a modular synth in its own right.
BUT
I'd like to have a bit more strictly 'modular' capability, whether it's some interesting ways of generating patterns, or a few different VCO-type sounds (ie digital oscillators or other sound-generation stuff), or maybe even something that takes an SD card for samples/granular. I make what could be described as 'sort of techno' (ie 4/4 etc) but also 'sort of noise' and drones. I like to run external stuff through it sometimes too like guitars or cheap poly keyboards. Basically I like to experiment!
So I've been looking at multi-function stuff a bit lately. The Disting seems to have a few nice things about it but it seems very small for all that functionality, and some of those functions are maybe a bit too 'utility'? I know some of the Mutable modules (either orig or clones) can do lots of different things. Part of this is budget; as you can see from all the DIY kits, I'm not rolling in dough!
From this very uncertain description of what I want to do, does anyone have any recommendations or suggestions of where to go next? I'm leaning towards getting something that works straight away but if something DIY could be got for cheap then simple through-hole only stuff is about all I'm capable of.
Sorry for rambling. Thanks for getting this far (if you did). Hope you can help!
