A fine, FINE example of specious reasoning. WMD closes shop, people make assumptions.
Let's explain something, shall we? First up, module manufacturers closing up shop is nothing new. We consistently lose several a year, and yes, some of them are big names. And while some of those have more annoying reasons (like Emilie finally getting quitting-grade discouraged after Herr Behringer lifted Plaits and Veils from Mutable's lineup), much of this is simply what you'd expect to find in an overheated field with lots of "churn". There's nothing odd about that...typical capitalism at work.
And yes, the current supply-chain fubar over electronic components is hitting everything, not merely synthesizers. That's the "changing forever" that's far more scary, with acres of cars waiting for chips sitting around idle worldwide being one obvious symptom. And yes, that shortage makes it difficult for synth companies...but it works the same way for any company that uses electronic components.
But when you get down to it, the components needed in a big percentage of modules aren't anything too esoteric. By and large, there's typically a larger amount of passive components (caps, resistors, diodes, etc) than anything VLSI-ish...aside of certain modules that are dependent on Atmel/Atmega, RasPi, etc devices for their engines. Since these passive components don't require any hi-tweak manufacturing methods (like UV litho), they're far less "endangered", and those components have made up the majority of what's on a module board since...well, Bob and Don.
And another big source for Eurorack devices is the used market, which apparently wasn't figured into the idea. There's a lot of used Eurorack out there, with a big chunk of that these days from erstwhile synthesists thinking they're ready to step up to modular...followed by a litany of bad choices and sales pitches...which results in plenty of viable modules popping up on eBay, Reverb, et al when these users discover that they got tossed into an infinite gulf of confusion (which this is IF you're not capable of doing some basic research) and not the wading pool. Frankly, I think overheated "analysis" like the above clip does more to HARM Eurorack, inasmuch as it attempts to spread a poorly-reasoned but seemingly-authoritative rationale for some impending implosion of Eurorack, etc. People that are incapable of looking into things themselves have long been self-generated problems in modular, and I (and others) have a bone to pick with "influencers" that use YT as a bully pulpit for nonsense such as that.
This is worse on some levels, though. Instead of being able to explain simple technical issues (such as why you're going to have trouble building a full system in 1 x 84), this hits more on some ontological level which takes advantage of potential users hearing this and then giving Eurorack a wide berth due to the general state of imposed panic these days. Boo. Hiss. NOT GOOD.
There's a big difference between causation and correlation...and there's more of the latter in the YT clip than the former. While I agree that losing WMD and especially Mutable is not a good thing at all, the only "changing forever" that's going on here is the usual constant change that's part of reality in general. And ultimately, that's not an actual change at all.
Sweelinck
This patch, inspired by the french musician and writer Boris Vian: ‘the monkey > the man > the fool’.
So sometimes it’s good to pull the plug.
GarfieldModular
Hi Lugia,
Thanks a lot for your great article on this matter. You mention several valid & good points. I totally agree here with you.
So let's focus back on having fun with Eurorack :-) Kind regards, Garfield.
