https://cdn.modulargrid.net/img/racks/modulargrid_2006291.jpg
Third iteration of this small build I centering around the tELHARMONIC. Looking for some feedback to see if I got this covered.
Nope.
No proper VCAs is a big no-no. Also, relying on JUST a Maths for all of your modulation duties is possibly asking too much of that one module alone.
A lot of this is happening because of the cab size. It's just too small. I know everyone wants to whip one of these things up, especially since you've got certain YouTube influencers showing these off as viable options for beginners. But they're not, because it takes way more experience and/or smarts to sort out how to cram ALL of the necessary modules into a single skiff of 104 hp or less (ESPECIALLY less!). Plus, with that Tempi in there, you're going to miss out on all of the cool stuff it can do when paired with a Rene mkii sequencer/touchplate controller because...well, space.
Rule of thumb in modular is to start with a case that you are 100% SURE is too big...because, invariably, it's not. Your build above could work fine in something like a Mantis, because that gives you the space to add all of the modulation, utilities, etc etc that can make those modules really cut loose. But in a single skiff, the results show some serious "sexy module syndrome", because you've got no room due to those "showcase" modules...which can't perform at their best without the utility, etc stuff. Sure, attenuverters and adders and so on aren't "sexy"...but they ARE essential.
